I created a custom drainage node. I want it to skew and shift it orientation with respect to the inlet. I changed the rotation and location of the bottom cell with respect to the alignment line and the point, however the cell translation has not updated. I tried restarting ORD, to ensure the Cell updates were up to date.
I had created this custome bottom cell (I named it something obvious because I wanted to make sure I wasn’t picking a default cell), you can see the skew and shift in the cell model below: I am using a standard top cell for our inlet.
In the drainage file I am in, I had created the element template, feature symbology and feature definition for the new bottom cell. The updated symbology takes the skew change but it looks like it is still rotating about the center of the structure. Is there a way to remediate this? To shift the top/bottom cell with respect to eachother?
Here is an example of what is happening you can see that the top of inlet is attached to the center of the bottom cell.
The construction lines and points were set to "By level" and Primary. The software does not like that, has to be set to a number and to construction class.
Answer Verified By: Emily Gordon
