Hello, I have a drawing with an imported LandXML which projects a surface. In order for AutoTURN read the surface, the LandXML/Geopack surface needs to appear as a triangulated Mesh so that AutoTURN Pro can use to generate a 3D simulation. Just to illustrate, I want to turn this:Into something like this (Surface Readable by AutoTURN):Any help would be greatly appreciated. Thank you!
Hi Michael,
A very simple way to do this is to just save the triangulated terrainmodel as dwg. After that, you can save the file as dgn again.
Regards Louis
Hi Louis, Thank you for your response. How would I save the LandXML terrain model as a dwg?
Would I do this procedure within the MicroStation interface?Again, ultimately I am trying to get AutoTURN be able to detect the LandXML surface.
In the screenrecord below you can see the way how I should convert a terrainmodel to a mesh:
https://youtu.be/4Du1USdrRww
With kind regards,
Louis
Thank you so much, Louis. Is it okay if I save this video when the similar issue is encountered?
No problem, feel free to use the video.
I appreciate it. Thanks again!
