Hello, I have a drawing with an imported LandXML which projects a surface. In order for AutoTURN read the surface, the LandXML/Geopack surface needs to appear as a triangulated Mesh so that AutoTURN Pro can use to generate a 3D simulation. Just to illustrate, I want to turn this:Into something like this (Surface Readable by AutoTURN):Any help would be greatly appreciated. Thank you!
XML is not a CAD file format. You cannot directly reference an XML into a DGN file. You can import an XML to create graphics in a DGN file, but at that point, you are working in a DGN file. That DGN file can be referenced into other DGN files, which is suspect is happening here. But I can't say for certain what you have without seeing your drawing or your screen.
You can find whatever DGN file this terrain is in, and use that DGN file to create the mesh as described here.
MaryB
Hi Michael,
In the screenrecord below you can see the way how I should convert a terrainmodel to a mesh:
https://youtu.be/4Du1USdrRww
With kind regards,
Louis
Thank you so much, Louis. Is it okay if I save this video when the similar issue is encountered?
No problem, feel free to use the video.
I appreciate it. Thanks again!
