Hi
I am using ORD 2022 R1. I cannot get cross slopes of subgrade to be annotated on cross-sections. Neither with all segments nor for created list of segments. It works as long as segments are on "top surface". If segments to be annotated are not on top, but on the bottom or at some intermediate level, no cross-slope is annotated.
And now, delivery, 800 cross-sections, urgent need to annotate cross-slope on bottom layer, and stuck. If the cross-slope is constant over along corridor, I would create a dummy annotation cell with fixed slope label, but slope of subgrade changes a lot.
Would appreciate any idea how to get cross-slope of bottom layers annotated on cross sections.
Adam
Hi Adam,
Are all the points on the bottom layer using a unique Level so theyt can be filtered? Perhaps a macro could be used to annotate them if they are easily filterable?
Unfortunately all non-Top Mesh points are invisible to the segment annotation currently. Hopefully fixed in the next release...
Mark
Hi Mark,
Yes, all points on the bottom layer have an unique Level an I can filter them. But how it could help me to annotate slopes between points on the bottom? Even when I am annotating all segments (not from the list) and filtering them by "on the bottom", nothing is annotated. If I chose to annotate all segments in a template with no filters, just all segments on top are annotated.
ahh i mean you may be able to create a macro to automate it. Question - does the civil labeler annotate slope between XS points work for these?
will try with civil labeler but it means I need to select every two points to annotate the slope between, every single cross-section. at least two segment on each of 800 cross-sections. they will finalize construction and I will still annotating crosslopes.
let me see if i have a macro that may help
