Configuration Variables defined in other workspaces are being left in the active workspace if not redefined in active workspace
I'm running into a issue when running several different Workspaces that configuration variables that are defined in one workspace are showing up in the active workspace. If the active workspace doesn't define or redefine the variable the variable will be defined by any previously used workspace.  Is there anyway to prevent this from happening or the have all variables removed and only define those that are in the active workspace.  This would include all levels Organization, Workspace, and Workset.
