Hi everyone,
just wondering if anybody know how to remove the "Black shadow" from my model?
It looks like this black shadow/area matches is intended to show the difference between models. See pictures below
Is it possible to remove it ?
Thank you,
I’m not sure, but it’s possible there’s something in the template that ConceptStation is picking up that is making it read like part of the model and causing the 3sm and aerial to be clipped like something’s there. I’d check your template and possibly also your geometry relative to the surface to make sure you’ve no surprises. Is this happening consistently with all ConceptStation models or just this one?
-John
OpenRoads Designer 2022 Release 3 | ProjectWise CONNECT 3.453
John Padilla
Thanks for the suggestions.
I ended up creating a dummy concept model and added a new design scenario. As expected (or not), the "black shadow" is no longer showing. My best guess it is perhaps my original model/file has been corrupted one way or another.
Answer Verified By: Marcelo F. DaSilva
