I would like to draw pattern lines along an alignment like Geopak did. Then I can create a dxf and load into a data collector to help with the survey. Any thoughts on how to do this? The alignment has curves so a simple parallel offset won't work.
Try the Construct Array tool set to Along Path (Mode to Both for distance and number). Utilize Civil Accudraw to define your starting line station/offset location of your cut line if necessary.
colliersengineering.com
Answer Verified By: Lucas Hicks
Looking for that tool...
Search Ribbon field for Array
So close!
Is that a 3D file? May only work in 2D. Make sure you have any 3D self-references turned off, If that alignment has a profile, it could be grabbing that element.
