I would like to draw pattern lines along an alignment like Geopak did. Then I can create a dxf and load into a data collector to help with the survey. Any thoughts on how to do this? The alignment has curves so a simple parallel offset won't work.
Well my PC decided to shut down on it's own. Started everything up and tried again (all files where 2D originally) and it worked. The only thing I did different was to create a alignment rather than a complex chain.
Thanks for the help.
