Printing shows Grid lines when printing double stack plan sheets with aerials but only on the bottom plan view.
The issue I came into with printing the double stack plan plan is with the bottom plan, as you can see in the example below the first image is the actual sheet view and there is no grid displaying at all but when I publish to print the grid lines only show up in the pdf but only in the bottom stack...  the crazy part is that is does not show in any of my views in the actual drawing or sheet view, so I am at a lost.
If anyone has come into this issue, please let me know it would be helpful.
Sheet View - No grid lines on bottom view
Printed PDF [ Grid lines show up on printed versions only on bottom view.
