Problem with Corridor 'Synchronize from Library' . Results in a change in Geometry (in it's snapped location)
Currently i'm running into a problem regarding the function 'Synchronize from Library' on a template in my corridor,
I didn't change anything in the template design. After using synchronizing, geometry that I added separately of the corridor (and snapped on geometry generated by the corridor), will jump its snappoints to another location.
It seems to still snap on the same horizontal geometry, but on another station in the corridor.
(In the example below there is a linear template on the geometry i've drawn separately).
Before:
After:
I noticed that the problem will not occur when using 'Edit template drop'. (But for me this is not a solution, because I have multiple templates in one corridor and want to change them all in one edit).
Does anyone know why this is happening? Is it working as intended and am I doing something wrong? Or is this a bug?
- Using OpenRoads Designer CE - 2022 Releas 1 Update 11 (Version 10.11.00.115) -
Thanks in advance!
Parents Reply Children
