Default-3D and Default models attaching independently.
ORD CE 2021 R2  Version 10.10.21.04
I've set up a file to cut a cross section at an entrance on my roadway project. When cutting the cross section I noticed the 3D graphics from the entrance (a civil cell referenced from another file) weren't appearing. Turns out the Default model was referenced to my x-sec file, but the Default-3D model didn't follow. The Default-3D isn't listed in the references for the 3D view while it IS listed in the Default list. Further experimenting I detached the geometry file of the entrance only to find that the Default-3d model didn't detach. Pic below: Default view on left, Default 3D on right.
How can I stop these models from attaching and detaching independently? The entrance and geometry files reference normally to other files (both Default and Default-3D models attach). I've used this exact workflow before without incident. Any help is appreciated. Thanks!
Parents Reply Children
