I am laying out a rough placement for a roundabout. I have the splitter islands and approach lanes dynamically linked to the inscribed circle, all were placed using the horizontal geometry tools. I want to move the location of the center of the circle but it does not allow me to shift its location.
Is there a way to retain the dyanamic relationships and shift the circle?
Emily
The Transform tool in Common Tools should move the circle. Typically, an arc for the inscribed works best and allows easier use of profiles on that graphic ( Arc Between Points tool set to Center\Radius Placement Method.)
colliersengineering.com
The circle wouldnt move with the transform or move element tools. I ended up using a point to tie the center of the inscribed circle. I was able to move the point and all elements with dependencies with it
Answer Verified By: Emily Gordon
