How can I create civil labels that have mathematical expressions on them just like in Inroads SS2 Drafting tools.
For example, if a pick a close shape to label the area, I can add an equation to the label to output the value in hectares instead of the value in the design file's master units (m).
Thanks.
I only did a simple circle as an example but, you can use the Element Properties when creating a text Field. There is a conversion Factor you can use if it is a simple conversion.
Ok thanks. I was more interested in automatically adding a set elevation to a label. So one point would add a gutterline and than automatically add similar label with a set exposure (6") for example that could be changed. Currently I'm left with xxx.xx :)
