Line geometry edit text not visible
Using Civil geometry, and snap at circle center with geom baseline active feature definition, I used line between two points to draw a line of exercise given in QuickStart for Geometry - Road fundamental. Everything went fine but after that when I select the line with element selection tool, the line length and direction text that appears along and is also editable doesn't appear. How come I view that automatically as in the tutorial video? kindly guide me to those settings.
Parents Reply Children
