All of my drainage inlets have disappeared in my model!!! They have been replaced with a generic box.
I am using Open Roads Designer (2021 Release 2) 10.10.21.04, FDOT connect.
The issue I have been having is that I designed a whole drainage network, had cut cross sections and was labeling the cross sections. I noticed yesterday when I am looking at my cross sections that my drainage structures were modified instead of being the cross section of an inlet, it was displaying a generic box that was not in the right location.  This is happening at all my inlets.
Below is what it is supposed to look like. This is from a pdf I had printed before.
I went back to my design file so I can see what was happening. I had originally drawn a Type 4 inlet in there but it was not just a box.
This is what the structure looked like in a previous PDF I had printed
Looking at the structure information nothing seems out of the ordinary.
I cant seem to change the structure back.
As a test I tried to place another inlet. But when I am placing the inlet there is no feature definition usually there is a picture of a drainage inlet that I can place. Instead there is a box that says STM on it. When I place the structure, it is not placed in plan view. However, if I go in to the node report I can see that the structure is listed.
I just tried to open the file a little bit ago and I saw the following message. I was not sure what it meant, and I hit no.
Can somebody please help. Any ideas of what it could be?? Is the file corrupted? Could it be an ORD setting??
Thanks!!!
Parents Reply Children
