San Diego had custom linestyles for the existing ground for Profiles in InRoads. In OpenRoads that custom linestyle is multiplied by the Profile Vertical Exaggeration.
when Vertical Exaggeration is set to 1.0, everything looks both hunky and dorey:
If the Vertical Exaggeration is set to 10, designers weep:
I can set up Terrain Feature Definitions for each Vertical Exagg. (requiring different Custom Linestyles (1/Exagg).
I'd rather not.
Ideas? Thanks!
Hey Jeff! ... I'm curious as to what the solution to this is too because I suspect that it the same issue that's scaling the Superelevation tick marks in the Super Diagram. It didn't do that in earlier versions, and seemed to have just become a problem around 2021.
Thanks, for indicating your interest. That bumps it up in the priority list, straight to the top.
Still a wise-guy, eh.
No, actually, I would think that if both you and I both have the same question, Bentley just might answer it.
The only quick option for this looks like copying the profile line into each sheet and turning off the original. OG profiles don't change as often as design profiles. Not ideal, but only immediate solution I can see.
