using a custom NYSDOT work space,
when i try to use the civil labler it pops up for second and just turns white
The Civil Labeler you're seeing in 10.11 is designed to use a dgnlib file for holding its settings and content. In 10.10 that tool uses an XML file you see in your configuration. Unless NYSDOT has a 10.11 workspace, you'll have trouble getting that tool working on their 10.10 workspace. There's a remote chance you could get someone to rewrite their Civil Labeler standards and workspace to work with 10.11, but hardly worth the effort when 10.10 can be installed on the same system as 10.11.
EDIT:
Karl Detrick said:ORD out of the box setting same results
This is likely caused by your company standards and custom workspace designed or copied from 10.10.
They'll need to rewrite some of their configs to work with 10.11. It's possible removing that CIVIL_LABELER_XML will fix that, however the contents may be blank if newer Bentley dgnlibs (containing labeler information) were added to the 10.11 workspace.
colliersengineering.com
Folks:
One would not have to "re-write" anything at all as regards labeler in situ if one has access to the Civil Labeler XML file. You can import this file into the 10.11 Label Definitions directory in ORD explorer. It would be preferable to do this in a WorkSpace defined dgnlib- specifically the Labeler dgnlib (assuming that this "legacy" dgnlib exists)- but you could import it into any dgn you would like as well. Just be aware that the labels/ label definitions would only exist in that dgn and would not be accessible from others. On the other hand, it is a pretty simple thing to just import them into any dgn which may have use of them.
Best Regards,
Mark
Mark Plum said:One would not have to "re-write" anything
Isn't there a config change that needs to be added to enable that "import" right click menu item? That Import option doesn't appear to be available by default.
Shawn:
Yes...
_CIVIL_STANDARDS_IMPORTEXPORT = 1
I have been so busy that I completely forgot about this one!
Thanks!
Placing this link here for further information on this 10.11 Civil Labeler change. I knew I saw it somewhere! Chuck has another Civil Labeler video for 10.10 (xml version) on the Bentley's ORD Youtube posted just 6 months ago!
