When creating cut and fill closed mesh for my quantity report, lots of holes are created in cut mesh as if ignoring the existing terrain at some random spots (See below) It only appears to do this in the cut meshes, not the fill.
Obviously this is a problem as my cut quantities won't be accurate. Any thoughts on what could cause this? (Tried with ORD 2020 R3 and 2022 R1. Both similar results)
Thanks!
Pat
Was the existing TM imported from an XML created in Civil 3D?
Hi Kyle, no it was created from a point cloud.
Try recreating the existing terrain from the triangles created from the point cloud TM. I have had this issue when importing Civil 3D XML files and this workaround fixed my issues. Hope this helps.
I tried your suggestion, and unfortunatly I'm having the same results.
Hi Patrick, are you using a Complex Terrain or have multiple existing Terrains on top of each other?
Mark
