Hi all,
When I was using InRoads SS2 I was able to create subsurface using the Import Subsurface command.
“This Add-In command creates subsurfaces relative to a selected existing surface. When executed this command creates temporary surfaces to hold data. The point locations are computed from the station/offset and the elevations are added to the appropriate surfaces with feature names and descriptions. These are triangulated. They are compared against the active surface as isopachs and against all points in the existing surface. The results are placed in surfaces named in the data file. They are triangulated and the temporary surfaces are removed. Subsurfaces are now created.”
Is there a similar command in OpenRoads that I can use to create subsurface or workaround that I can use?
OpenRoads V. 10.10.21.04
I checked an old video here. https://www.youtube.com/watch?v=V2T7AFvLjBY about InRoads subsurface command.
If you are looking for similar function, under OpenRoads Designer, you can try Geotechnical tools here.
