Hello, I have a big problem with civil rules.
I have some Feature Definition Points added with civil accudraw tool and they are attached to the reference alignment. Unfortunately my referenced file must to be replaced coulpe of times (I get a road alignment in xml file so I always need to import this once again to have the newest version) and after replacement my civil rules are break because of ID losing. Is there any option to reattach or redefine those rules using any tools or Item types or even generative component? There is an option to redefine corridor but what solution do you recomend for utilities or drainage or LV Assets or any other feature definition added?
We want to work with many disciplines on OpenRoads and OpenRail but I have doubts what to do in case of any reference replacement.
You have to use the command Geometry Substitute, to "exchange your old alignement" with the new one. See this thread: Major alterations to alignments and geometry - OpenRoads | OpenSite Forum - OpenRoads | OpenSite - Bentley Communities
It basicaly replace an alignement with an other and everythings/rules are swap to the new alignement.
Try it I'm sure it will work
Answer Verified By: Natalia Pikor
