I'm going insane trying to figure this out, I'm pretty sure this is the easiest fix in the world but I'm just too ignorant.
I have two surfaces, one is from an old survey and one is a new one. All I want to do is overlay them, display cut and fills, cut cross sections to show the differences, and then get my volumes reports. I set the old survey as existing and the new one as design, generated the cut and fills, and cut my cross sections, but now the reports are not reporting.
I can't use the Corridor Reports because there aren't any actual corridors, so that's off the table.
The Cross Section Report tool from Civil Analysis doesn't work because after generating the Cut and Fills the surfaces revert back to "None" for their volume option and I can't change it anymore:
This also means the End Area Volume Report shows up empty. Hell, even my Drawing Model Annotation tool for the actual cross-sections turns up blank:
So I have my 3D cut and fills but nothing can read them or analyze them? I don't get it.
I'm assuming I'm just using the wrong Analysis tool, what should I be doing here?
Hi.
Hope following link can help you.
communities.bentley.com/.../no-existing-surface-found---cut-fill-volume
Thanks & Regards
Babulal Sahu
Road & Railway Alignment Designer
