I recently had to update the trunkline for a drainage network. I am updating the hydraulic run to outfall but when i click the prompts, I get an exception log.
If I use the hydraulic run from node and click the last node and click the outfall it follows the old layout
I have redrawn the conduits, but i am still getting this error. I have compacted the database and resynched the drawing also, but these issues are still persisting.
When i do the model integrity check i get these errors (see photo below) It looks like there is some miscommunication between the database and links, I am unsure how to remediate these issues.
Is this file salvagable? I am apprehensive to start new file from scratch because there are quite a few custom feature definitions being used for different sized manhole bottoms.
Emily
No replies to this yet? I suffered the same error yesterday. I was able to recover an archived file but still lost a good amount of work. I would love to know how this error crops up, because it seems to be able to effectively kill a DU file without an easy fix.
Im pretty sure what is happening is that the SUE database isnt in sync with the dgn model
