I see new videos have dropped for this release.
https://www.youtube.com/watch?v=kd6hgQ20OvU Thank you and about time. This is now very similar to C3D except theirs has a list. This will make editing terrains much easier and was much needed.
or component meshes for layers thinner than 5 cm showing 0 volume :(
The ArcGIS Import functionality is a little different than what the video shows... The keyin is different, the dialog box is different....AND the features don't load... I connected to the same rest server as the video shows too.
Ok so it's in OpenRoads, just wondering why it's not available inside OpenRail Designer?
https://communities.bentley.com/products/rail_design/f/openrail-forum/243517/import-arcgis-missing
Can you place the Key-in you are using inside OpenRaods?
//Christiaan
Yeah, except not the exact key-in that was used in the video
Hi Charles, can you clarify what is the correct key-in?
Mariusz
OpenRoads Designer 2022 R1
