Hello everyone,
Are facing issues when trying to annotate side slope after clipping a corridor?
PS : I'm using OpenRoads Designer 10.11
True, when you clip you are probably clipping out the point that is needed to annotate the slope. The Annotation Group would need two points to generate a slope annotation.
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
Yes true, however it should still annotate the slope where the corridor is not clipped.
Let's say for example that I have a corridor that is clipped in the middle (see the image below), is it impossible to annotate side slopes in this case?
