Can I display contours label in corridor ( ORD CE)?
Will it be updated when I make changes to profil?
You can develop a terrain using a terrain by graphical filter, similar to this V8i video. The terrain needs to have a Feature Definition (or override) utilizing a contour based Element Template. When updates are made to elements found by the filter will be reflective in that file. File federation best practice is to have that terrain in a separate file which would need to be opened to update any changes made to referenced corridors.
colliersengineering.com
Hi Marek,
You can enable a setting in your Corridor Feature Definition to display contours. These contours will always be updated and in sync with your corridor elevations.
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Thank you Shawn,I make a terrain from corridor with contours and label (in separate file) and attached it to corridor. Get what I want for this moment.Still have the question, is there a way shown it in corridor without terrain steps?
After I get corridor with contours I proceed it in Cad, but this time (ORD) I can't export contours with automatic label to it.Do you have some solution for that?
I saw the labels made manually is showing in 2D - cad or dgn, but not this "automatic" one.
Hi Mark,
thank you for your answer.
I got this - I can display the contours how I want, but I want see also labels on them in corridor.
I see value of each when I stopped the cursor on it - in separate window text, but can't display labels in any way.I use method explained by Shawn and it is working temporary (few next steps to do - and you have to remember to open the drawing each time you changed something in corridor or profile) .
