End COndition Exception Parent Component Relationship
I have a corridor which has a berm and end condition arises from the berm. I had made the end conditions as child component of the Berm. When I apply end condition exception, the end conditions do not respect the parent child relationship. The end condition is displayed even at locations where the berm is turned off. I had also redefined the Parent component in the end condition exception window and the result is the same
Doesn't open roads consider the parent component which are not defined as end conditions if End condition exception is applied.
