Sump Depth? 2022R2
I see in the new release ORD CE 2022 Release 2 there was new sump depth capabilities added.  Does this require a modification to the Node Cells to make this work?  I have changed my Manhole to Start/Stop Invers Use Sump Depth = True and set my sump depth to 24" but the 3D model does not show any sump depth in the manhole model.  Is there a delivered example of a Manhole or Inlet that has a sump that works like the 2022R2 video shows?  It does not really seem to work as described in the release video.
  • Where in the Drainage Feature Node definition do we add the sump depth?  In the video https://youtu.be/jEcA9zhCuLA the sump is predefined in the Node Feature definition i.e. "ManHole (With Sump)" but I do not see options in the Feature Definition to define a sump unless we modify the cell which hard codes a sump the th3D model but not in the Analysis or invert properties.
    If I make sure to define the Sump in the Inlet node prior to adding the conduit the sump does seem to work as Show in the video.  If I change the sump after the conduit is added the inverts do not adjust.  Is there a way to make the sump value dynamic or update the inverts without deleting and replacing the conduits?
    Mike Longstreet
    Vermont Agency of Transportation
    Civil Engineering Technical Support
    VTCAD Help
