If you are dealing with Georeferenced data to build elevation models, then please read this article to prevent errors in Elevations
Best Regards
When is this going to be fixed? Are there any versions of ORD that do NOT have this bug?
MaryB
I can't answer for first question, all ORD versions are impacted.If you need to apply these type of workflows, then please log a Service Request to help manage priorities.The workaround is to strip GCS from source data (or work from a non-georeferenced file).Best
Vincent RAULT [Bentley]
We import LAS/LAZ files. Are the geo-referenced point cloud elevations correct at import (when the pod file is created) and the error occurs when the geo-referenced point cloud is used to create a Terrain?
Sorry for late response.
The issue arises at referencement (LAS/LAZ attachement and POD creation). POD Elevations are incorrect.TM from POD will also be incorrect (and STM will be 2 times lower) STM in red and TM from POD is blue.
So Best practice is to work from non georeferenced DGN or strip GCS from incoming data
