Right Click to bring up menu in Inroads SS2 style manager not working
I'm trying to export from style manager in SS2 to create templates in OpenRoads Designer, when I select the style and right click to export to an xml, no menu comes up.
Any thoughts??
  • Jason, it doesn't work in InRoads SS2. In InRoads SS4 (and maybe SS3) you have to go into the Style Manager and toggle on the filter Include Surface and then you can select the Styles in the bottom pane, <R> and the Export to XML will appear. But it only works on Styles that are set up for Surfaces. To get other Styles you need to go into those Styles and toggle 'on' Surface and then you can export those as well. .. but if the Style is set up for only Geometry or Survey it won't work on those Styles. ... Hence toggling on 'Surface' on those.
    Civilly yours,
    The Zen Dude (also known as "Mark")
    Civil Software Guru & Philosopher
    InRoads User since its birth in the 80's
    OpenRoads Documentation / Training / Support
    Zen Engineering, Owner
Reply
    Civilly yours,
