Drainage and Utilities: Updating Hydraulic Runs
Is there a way to update profile runs created from the "Hydraulic Run from Node"?
I am modeling a Drainage pipe network and several catch basin locations have been moved slightly in plan and have different inverts. I already had these profile runs on sheets before the updates, however after the updates were made to the nodes the profile run does not reflect the changes on the sheet. I could delete the old profile run and create a new one and replace it on the sheet however this process would take a long time for such minor changes. So that prompts my question, is there a way to update these profile runs without creating new ones?
