Using the command "Complex Transition Between Any Element and Arc". I want to draw R=100 L=90 L=90 between an element with Line and R=15000, but it doesn't work. If R=203 it draws. How can I do that.
Hi, this looks to be strange behaviour of that tool.
Try the "Arc Between Elements tool" and you will see it will solve the criteria you have shown above. I suggest you log this issue with the Complex Transition tool in as a Service Request.
Mark
Hi Mark
"The Arc Between Elements" tool only works correctly between two lines.
"Arc Between Elements" does not work correctly when drawing radius and line. It shifts Klothoid into radius.
When we draw using Inroads V8i, it gives the correct result.
Gündüz
Hi, I am not aware of this issue - can you share some information as to what the correct result should be?
