Offset value is entered but not show in drawing.
5305.Offset Problem.dgn
I downloaded that file and had a go in Update 12. That appears to be a bug... It will not honor the offset you require... which is an issue as that tool is the only one that you can add in a double spiral.. I will log that SR for you and post a defect number when they send one to me
Ross
Just spoke with a colleague a work around for that bug would be to offset your straight element first ie the 15m add that element to a construction class.. then run that command again...
Hi Ross, Many thanks for that workaround.
We have a defect logged fir that issue.
for your reference is Bug 820930
Hi Ross,
Thank you for your interest.
