I cannot draw the line between R=5000 and R=460 with R=400 and backward L=100 forward double spiral R=90 L=90 and back offset 15
I am attaching the dgn file and the jpg file.
Arc Betweens Arc Offset.dgn
if i use "Complex transition between and any element arc" command it doesn't do offset
Regarsds,
Arc Betweens Arc Offset_Complex.dgn
Hi Mike,
The error should be reported to Bentley, can you do it
Regards.
