<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>ORD 2021 R2 Template Controls - Template preview vs. modelled result</title><link>https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/244290/ord-2021-r2-template-controls---template-preview-vs-modelled-result</link><description>This question is a result of attempting to model daylighted subbase (where possible) so we would be interested if others have found methods to accomplish this.
 Background:
 We are attempting to create a roadway rehab template that is full width to</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: ORD 2021 R2 Template Controls - Template preview vs. modelled result</title><link>https://communities.bentley.com/thread/762262?ContentTypeID=1</link><pubDate>Mon, 17 Apr 2023 15:06:40 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:3f5e607e-e89d-43fb-82cf-cf4394e64869</guid><dc:creator>Shawn Cooke</dc:creator><description>&lt;p&gt;To target another proposed design you may want to try the Corridor type Point Control option.&amp;nbsp; That will give you a list of points in an adjacent Corridor.&amp;nbsp; Another option is to use Target Alias to target specific linear named graphics.&amp;nbsp; Over the years, the &amp;quot;Project to Design&amp;quot; hasn&amp;#39;t been all that useful for me.&amp;nbsp; Maybe lack of time spent testing its use... but typically resort to things I know have worked... &amp;quot;if it&amp;#39;s not broke, don&amp;#39;t fix it&amp;quot; mentality.&amp;nbsp; I&amp;#39;ll also note that the Vector Offset functionality is hit and miss sometimes.&amp;nbsp; Try using the = sign out to the right of a point constraint&amp;#39;s value field to specify a slope or distance of two totally separate points in the template.&amp;nbsp; This works wonders for points that tend to overlap or meet at zero.&amp;nbsp; A few tips there that you can use to aid your search for &amp;quot;better training&amp;quot;.&amp;nbsp; Those topics should lend some additional options to things you&amp;#39;ll need to accomplish... since there isn&amp;#39;t really a one-size-fits-all approach.&amp;nbsp;&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
