Annotation for PI and PVI without Curves
How do I annotate definition for my complex geometry to annotate PVI and PI (station and elevation, where applicable)?
The annotation definitions I currently have only, only annotates the intersections with curves applied to them.
On the vertical geometry, the grade breaks are displayed with a marker like a circle or triangle. And i'd like to add the station and elevation.
On the horizontal geometry, nothing is added at all.
  • I'm interested in this as well. We have plenty of small scale projects that are not designed to full "4R" standards, which means that we do have an range of deflection that doesn't require vertical/horizontal curves, but we still need to label those PVIs with a certain amount of information. The one I am often at a loss for labeling is horizontal delta angle when there is no curve.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • This topic is not new -  RE: ORD Horizontal Annotations for NON CURVE PI Points
    But the solution has varied from version to version.  I am running into the same\similar issue but with version 2022 10.12, when using Horizontal Points - P.I - All Curves only the curve PI's are labeled but if Horizontal Points - P.I. is used all curve PI's and none curve PI's are labeled.
    Another option is to use In Horizontal Components - Arc Left or Arc Right and then switch the Components option to Point of Intersection which will only label curve PI's.  There is an option of Horizontal Components - Line with a Components option of Point of Intersection which you would think would work but it does not because all PI's are labeled.
    Another option is to used Horizontal Points - POT but you would then have to set the config variable CIVIL_LABEL_POT = PI so that non curved PI's would be labeled as PI and not POT.
    Just seems there is not one clear cut solution to this.  I would like to see this enhanced to just have one option of a non curve PI as a selection when applying annotation definitions.
    Sean Keene
