We are running FDOT Connect on the 10.11 release. We just implemented 10.11 this month, and the civil labeler some how is worse.
Here are the issues we are having:
1. Undo button deletes all civil labels, and you can't undo
2. Some labels will rotate to random angles after you leave the file that we can figure out (it's not the unrotated angle)
3. The civil label manager is now gone from the civil labeler dialogue box
Has anyone had these issues, and what have been your workarounds to successfully deliver a quality project?
Matt, Did you ever find a solution or workaround? I'm having the same issue with FDOT Connect, ORD CE - 2022 Release 1 Update 11 (Version 10.11.00.115).
