Hey all:
I have a .dgn file that contains a mixture of 2D lines and 2D smartlines that represent the proposed contours. What is the best procedure to convert these for using in creating a DTM?
Using Geopak Eng Suite V8i.
Thanks!
2D linear elements can be used to build a DTM within GEOPAK using the DTM>Extract Graphics (Mode = Interpolation).
To accomplish this, the software needs two (2) pieces of information. One (1) the linear elements AND two (2) text values that represent the elevations at which the linear elements are expected to be set at.
Do you have text values on (or near) the linear elements that designate the expected element elevations?
If yes; using the Interpolation Mode, you set the symbology of the linear elements and, in a separate panel on the dialog, set the symbology for the elevation text and then "extract" to create the DAT file. When the DAT file is complete (you can append as much data as necessary), you will triangulate the DAT (DTM>Build DTM) to build the TIN file that is the basis for design within GEOPAK.
You will note that there is an "extract tolerance" at the bottom of the dialog. This is a scan distance that tells the software how far to scan from the vertices of the linear elements in an effort to find a text value that designates the vertice elevation. The scan is measure to the justification point of the text.
HTHs,
Michael
Hi Michael:
thanks for your help!
greg
Hi Greg,
I'll tentaively answer YES.
Once you build the TIN from your graphical elements (as discussed earlier in this thread), you can import that as an Object into Modeler.
Then:
1) Create a new Object (type Parking Lot would make sense).
2) Drape the graphical elements that make up your Parking Lot onto that Object that was created by importing the TIN.
3) Now your PL Object has the graphical elements and it should merge in your Site Project so you can do the other Objects (ponds, buildings, roads etc).
This does seem a more difficult way to do things. I'd typically suggest you design the Parking Lot inside Modeler as well as the other objects. While I've always found grading linear elements using the Site Modeler tools the most efficient way to design Parking Lots, you can still use contours if thats the way you want to design... Just add the contours within Modeler to the PL object.
Does this help?
Yes that helps!
Some questions on the Tolerance setting:
If a spot elevation is within 0.75 master units of a longitudinal reference, the software projects the spot onto the reference (perpendicular) element and uses the elevation to interpolate.
does this mean that the text must be within 0.75 (or whatever the setting is) perpendicular to anypoint on the line?
2. from help:
Spot elevations can be represented by graphical elements or text. For each MicroStation longitudinal reference element, GEOPAK locates the spot elevations nearest to and on either side of the element endpoint. Then, the elevation at the element endpoint is calculated. For example, the example shown below calculates an interpolated elevation of 137.57 from elevations located 10 meters and 25 meters on either side of the element endpoint
what is this talking about? Is the text assigned to the longitudinal reference to the nearest perpendicular or to the nearest endpoint?
Only been with Microstation and GeoPak for 3 weeks but...
So far the support from Bentley has been amazing!
