Defining existing topsoil layer.
Hi!
I'm working as Road Designer in PowerCivil.
Would anyone help me with how to define existing top soil layer (usually in different thickness throughout along the road) so I can see it when suraface is created?
Thanks.
  • How is this layer defined? You say different thicknesses - how are those determined?
    Do you want to create an actual topsoil surface, or would you just need it to show up on your cross sections.
    You say "PowerCivil" - would you be able to give us the exact version number?
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • MaryB,  thanks for involving!
    So, for example, my road is 1 km long. Then, let's say first 200 m are with topsoil depth 0.20 m, then next 400 m with depth of 0.30 m, et.c.- it differs throughout the stationing.
    I shall make a submission where designed road and existing surface is shown (existing surface shall include the topsoil's thickness). I would also love to have it in the cross-sections, of course.
    PowerCivil is for Middle East V8i Version 08.11.09.789
  • I'm not familiar with PowerCivil - I'm used to PowerInRoads and PowerGeopak. Does it use templates? or is there another way for it to model cross sections?
    If those are done with a template, you might have the ability to define a cross section "stripping" feature that follows the existing surface at a defined depth. You could possibly use a variable that you would control with a parametric constraint to define the depth from station to station. You may have to read in the Help how best to do that.
    MaryB
Reply
    MaryB
  •  , just want to make sure if we speak about the same thing. So - I have created existing surface from topography data. Then, I create vertical aligmnet, adjust typicall cross-section and create corridor. So, what I'm interested most is that at during some of previously explained steps I define how thick (according to geological investigation) is topsoil layer, so I can define it through my road. For example, I define that topsoil is const.0.20 m thick, and I can see the actual line when roatating my design in 3D view, and also I can see the line when creating single cross-section at stationin on my choice. Is this something You ment before?
