Importing Geotechnical data into ORD using an excel file.
Hello there.
I am currently working in the geotechnical ribbon workflow.  I have an excel file of all the information needed for the required Borehole tab (e.g., Easting, Northing, Elevation, and Hole Depth).  Also, in the excel file I have the lithology information (e.g., Top Depth, Bottom Depth, and Levelthe Lithology to construct bore holes in my design file.  However, it does not give me the option import the information from the Microsoft excel file into ORD (see photo).
Any reason why?  I am not familiar with the .gpj Project extension or the Microsoft SQL Server .Net Provider
How do I import the geotechnical data into ORD using an excel file?
Thank you.
Parents Reply Children
