Cross Section Name Boundaries
Hello Team,
I have laid down some Name Boundaries for Cross Section sheets but I was wondering, could you add a name boundary to a name boundary group that has already been created for us to show areas of importance? Some of these areas don't land on a name boundary so we were wondering how to do that.
Thank you for your time!
  • Enrique
    Yes you can do this. The trick is the following, go to the named boundary tool, place named boundary, when the next dialogue box comes up under group do not select new but use the drop down arrow to pick the existing named boundary group. Pick your alignment element again and then type in a new cross station value.  I usually do them one at a time so start station and end station. Then left click to accept that will then place the new named boundary in the group in the correct stationing order. I know this works in Update 10.
    Ross
Reply
  • Enrique
    Ross
