I am trying to come up with a strategy for a custom Sheet Index property (In my case a Project Name) that may need to be anywhere from 1 to 3 lines when placed in the sheet seed title block and the final result needs to be properly center-center justified. Using a separate custom property for each line doesn't work, as they populate with "####" if you leave the property blank and it wouldn't justify properly for a 2 line Project Name.
This would be a place where being able to put the old school "\010" in the property's value for a carriage return would help, but it appears that doesn't work at all anymore.
The Sheet Index is finally working well for us with regard to numbering. It would be disappointing if we ultimately had to adjust title block text on every sheet. Hopefully, there's an obvious solution and I'm just missing it.
We use project border reference files. any text that is common to the entire project gets placed in the reference file. Only data which is unique to a sheet needs to be placed in the actual sheets. We even have discipline specific areas where information common for all sheets for a particular discipline can also go in the reference border.
Thanks. That's how we used to do it for SS10. For the ORD DOT configurations we work in, the border is part of the sheet seed dgnlibs or sheet seeds...and there are many of those in the configs. For one DOT the border is a cell, not a reference. I'm looking into getting the dgnlibs to look in the project directory for their border, but that seems like a lot of configuration calisthenics to go through when the Sheet Index ought to be able to handle it. We could also create references for each project with just the border info, but I would like to avoid "have to touch each sheet model" solutions or have to write another script to do it.
Giving this a bump. Curious if anyone has found a solution to multi-line text properties in Sheet Index.
Also curious if anyone has found a solution or a code that could be entered as a placeholder for an index property that solves for the "####" so it displays empty. Something similar to this in Autodesk Sheet Set Manager. cadtips.cadalyst.com/.../ensure-empty-sheet-set-fields-stay-empty
