Hi all, so I created the linear template for back of existing curb after i set its profile active.. then I wanted to create a corridor reference to the EOP so that my existing curb extends to it. When I use the command, I choose first the corridor which is the back of curb that I created, then I click on the EOP reference.. and nothing happens! in 3D modeling there is still gap between the curb and the eop.
Any idea?
thanks, appreciate your help!
Hey Ted, If the following example doesn't help, please provide more details regarding the template used (screenshots, point control dialogs, options enabled, etc). Also provide plan view showing quick properties or info for the EOP/BOC graphics to better assist. Chances are, your Horizontal Feature Constraint isn't enabled or the EOP feature doesn't match that point dialog option. There have been cases where existing survey graphics using b-splines have caused your Corridor References method to fail. In those cases, a horizontal Point Control may be necessary.
colliersengineering.com
Hello, I was wondering if you were able to fix this issue and if you have any advice I can use. since I'm running into the same problem
thank you
