In ORD, I created an alignment from a LandXML file (exported from Civil 3D). The alignment has since changed in Civil 3D, and I have a new LandXML file. Can I bring those changes into my ORD Alignment without recreating it?
TIA,
Adam
Hi Adam,
The imported Alignment has actually been created with a rule, so as long as the updated LandXML Alignment has the same name, you will see it will dynamically update the previous imported one to the new one - retaining all linkes and relationships to other elements in your ORD model. Short answer - yes.
Mark
