Flex Table not displaying Baseline Station or Offset for catch basins??!?
You can see in the image below that CB 9 does not display baseline station and offset although it is setup correctly in the properties. If I re add the baseline reference it will then break the station and offset from 2-5 other catch basins. The only way around it is to select all the catch basins at once and then add baseline reference again. But it I move anything or add a catch basin they break again. It is very frustrating. Does anyone else have this problem??
