I have created an complex alignment using line between points and arc between elements tools. Now I want to adjust the curve length. There is no option in text manipulator or table editor for changing the curve length. How can I change the curve length in this complex alignment?
You can use Geometry Connector between line1 and line2 where you can fix the radius length and free the radius and lines length, then compute to get the solution
