End Condition Exception - Components Distorted
Hi
I have a template with pavement layers extended to End Conditions. I have applied end condition (Override) and removed "check for interception" from fill component. The constraints of the marked points are getting removed in the end condition exception (override) window . Even after providing the constraints again, the points lose the constraints every time the end condition over ride window is opened.
When the corridor is processed, the adjacent components are not matching. THe Vertical marked points are duplicated.
Any Help on how to use the end condition exception in such circumstance is appreciated. Please Advise
