I have a landscape area that is irregularly shaped with arcs. How do I adjust the survey codes to close it with a curve? I want point #2307 to close back to #2302 with an arc, but I can only close it with a line. See the screenshot below.
I'm not sure you can. What I do is remember or mark the first shot, then shoot the last closed shot close by, within tenths. Looks good are paper and doesn't affect anything in a negative way.
You could also create a point in your csv as well and next to the figure that has almost the same coords as the start and change a few linking codes. Or create a dummy point in the dgn after download and edit the figure and codes to include this. Just a thought.
You should submit an Idea - Add a Close Curve code to supplement the Close Shape code. We could also use a Three Point Circle code.
