Has anybody come up with a way to prevent the stacking (or bunching) of Cross Section Annotations in the Annotation Group Settings? One way I have used in the past is setting specific ITL points within the Annotation Group to label, but that only works for that one project/group of cross sections. The other idea I had was to put a bend (and an offset) in the annotation callout and leader to offset that point from being places on top of an adjoining point, but have not tested this yet.
Above are screen shots for what I am referring to that I did manually. If anybody has any thoughts on how to do this in the Annotation Group Setup, please let me know your thoughts. Please and thank you!
Openroads 10.12
Frame annotation can be used with the collision settings to bend the leaders and annotate the drawing models.
Paul Cusack There are a few other tabs of settings and unclear (possibly outdated) requirements this method needs to work as you present (e.g. requirement for Text Favs).. but good to know it appears to work that way with some tweaking! Please share if you're familiar with a training video or learning path that specifically walks the user through those settings.
colliersengineering.com
