When I activate the button and click on any option, I get "unknow key-in or command" error.I am using Openroads Designer CE 2022 Release 3.
I request your help in this matter.
I did the steps in the video, but the result failed again.I get the same error.
By the way, I've been getting the same error since I first installed the program. I reinstalled it. No change.
did you try using the key-in directly?
No.
Tell me please how to use it.
hit enter or use this tool
then in the window that opens type CIVILCOORD TOGGLE, if that works then something is wrong with your toolbox. you should actually get autocompletion as you start typing if the command is avaliable. maybe also try CIVILCOORD ACTIVATE and CIVILCOORD OPEN TOOLBAR while you're at it
if it doesn't work something is probably seriously broken with your workspace or installation. but since you said you reinstalled the app clean and cleared your user prefs, i guess it would be with the workspace.
have you tried using the delivered workspace?
