OpenRoads Designer. Issue with Place Node command.
OpenRoads Designer CE 2021 Release 2 - 10.10.21.4
Issue 1:
If I create a sewer alignment using the Geometry>Complex Geometry>Complex by Element tool I must set the Sewer feature definition to active in level manager in order for the correct alignment graphic to display. Must I always set the feature definition to active before creating alignment?
Issue 2:
Generally, just having issues with placing nodes. Sometimes nodes do not appear when placed, but, If I open the conduit profile the node appears to be placed.
Any help would be appreciated.
